Digitronical
- 71
- Feb 8, 2004
st louis,
Missouri
Hi guys, I have been looking at purchasing a new car. I have a 97 GST spyder with your basic bolt ons to the stock t25 and motor. I was convinced my next car was going to be a gsx, until my brother convinced me to look into the 93-95 MR2 Turbo. He mentioned it was the cheapest way to go quick and have ferrari like handling ability's.
I am more open minded than just quartermile racing, but autox and tracking abilitys, ontop of being able to put down a respectable quartermile time.
When he started going down the list of things the MR2 comes stock with for its cost, I started to become convinced that the GSX might not be the next car for me, keeping in mind that I am a budget minded tuner here.
He mentioned that the MR2 could outbrake a 2000 Ferrari 360 Modena, back in 1993, with 60-0 in 107ft, as well as getting the same skidpad results as a Ferrari F40 (.94g). With numbers like those on the stock brakes and stock pizza cutter 15" rims it comes with, I am convinced that there is much more room for improvement despite its amazing numbers it puts down already. He says that with the mid engined placement and its rearward weight bias, it gets much better weight distribution under braking and acceleration than front engined cars do, and its already lighter than a gsx with his weighing in at 2700lbs on an 18wheeler scale.
He has a JDM gen 3 3sgte, which ran a 13.3 in stock form, and an additional $250 in bolt ons to it and bald street tires, it ran a [email protected] and was told he wasnt getting very hard on it at the start due to its subpar 1.99 60ft. He says drag radials would of helped out a lot.
I like the fact that it doesnt have an interference engine, so if the timing belt breaks, I am only a timing belt away from getting it back on the road. It also comes stock with a metal headgasket, 540cc injectors, an iron block/aluminum head, stock oil catchcan, stock LSD transmission and some even came stock with widebodys and 500hp from the factory.
I think thats the thing that makes it a difficult decision, is that the MR2 already comes stock with so many upgrades over a GSX and is classed with AWD cars in drag racing over in Japan, due to its superior weight distribution MidRear setup, gets better gasmileage, and the 3sgte has won more JGTC's than the 4g63, and if your lucky enuff to find a TRD2000gt, you can get 2425lb, 493hp stock widebody, all %100 stock.
Now the GSX that I had been considering for uyears b4 I considered the MR2, doesnt come with a non-inteference engine, so if the t-belt breaks, Im screwed til I can save up enuff for a rebuilt head. I dont like how it comes with 450cc injectors, no oil catchcan, and a headgasket that isnt metal.
340whp on stock fuel system seems to be par for these gen 3 3sgte MR2's with mild bolt ons and a 50trim, I am afraid it might cost me a lot more to get a GSX to put down those kinds of numbers and outhandle or outbrake an MR2. My brother claims that the Mr2 will give me better handling/braking/fuel milage, better build quality, cheap to mod considering I can get a 50trim kit for a MR2 off ebay for $700.
Asa budget minded tuner, what car do you think I shud get since I want to tie or beat my brothers MR2 while spending as little as possible. Can I put down 340whp w/ a gsx AND run an 11.9? He did it all for $1500 and I wud like to do the same.
^Pic of said car, I want to be fast enuff to pull of a plate similar to this one.
...Not to be a dick but its the truth its a turtle
