TALONTRAX
- 470
- 5
- May 16, 2006
Southampton,
Pennsylvania
Does anyone recommend a turbo manifold as a stock 2G replacement?
Be more specific!!! Do you mean does anyone recommend replacing your cracked manifold with a good stock manifold? If that is the question I think a 2g manifold is an excellent replacement part for you. I would first find out what caused your old one to crack. EXAMPLE: running to much boost to the point where it was glowing orange.
If you wanted a replacement, and a cheap one. I would recomend the evo gt manifold. It can be found at turbochargers.com. I have never heard a bad report on these. There pretty much a ported evo manifold for 145 dollars.
