Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
Reply
LinkBack Thread Tools
Old 12-25-2007, 04:22 PM   #1 (permalink)
New Member/Lurker
Region: Midwest
Classifieds Rating: (0)
Reputation: DSM36 is an unknown
6 bolt rebuild help new rings.. HELP PLEASE
Alright well im about to do a rebuild on my 6 bolt i did a compression test and these are the results
100-130-127-125dry
190-192-194-188wet
the way i see it, its bad rings so i was planning on ripping the block apart in the car and just buying new rings for the old pistons, and replacing the rod bearings while there out? is this a good idea or should i just leave the bearings? and is it ok to just replace the rings on the stock 1g pistons, i also have a old 7 bolt that got crankwalk so i could possibly have 2g pistons to swap for the 1g pistons? what do you think?
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 12-25-2007, 06:27 PM   #2 (permalink)
Proven Member
cruisintalonawd's Avatar
Region: Rocky Mountain
Classifieds Rating: (2)
Reputation: cruisintalonawd is an unknown
The 2g pistons in 1g rods will need some machine work and you'll need need new bearing. if you luch then all you need it ring you might need to have the block oversized. and while apart I would have the head gone through buy a machine shop too
Offline
Old 12-29-2007, 02:40 PM   #3 (permalink)
New Member/Lurker
Region: Midwest
just started tearin it down today in my shopping for rings i found beck arnley as well as hastings chrome rings, any opinions on which may be better? I have arp head studs and a stock head gasket on there now but with plans of about 350hp do i really need the head studs? or could i just get head bolts from autozone and run thoes?
Offline
Old 12-30-2007, 12:19 AM   #4 (permalink)
Proven Member
Region: Pacific Northwest
Classifieds Rating: (4)
Reputation: 90gst_sean is more helpful than not
I blew two head gaskets on a 260hp engine before I got arp studs and MLS gasket.
I have 2g pistons and would only recommend them if:
1- you have good logging capability
2- you have fuel control
3- timing control or extra detonation control ie front mount, water inject.
with out 1 and 2 you may regret the swap. My 2g pistons forced me to purchase link before I really needed it.
As far as the build goes. If you've got a second car and don't mind pulling your engine any time you need to, you can really get away with what ever works for the moment. But if this is a major project for you, I'd hate to see someone spending a week end, a hole week, some people even a few months working on their car; just to half ass it..?
In the past two years I've :
pulled my head (head gasket)
pulled everything (full rebuild)
pulled everything again (engine swap to awd)
And now im starting a tranny rebuild.
Some times the cash will make your mind for you
I want you to have this " . " It took me a second, but I get it now... If I were you, I'd just go with stock Mitsubishi replacement rings.
Offline
[posts] [gallery] [blogs] Reply With Quote
Old 01-04-2008, 09:34 AM   #5 (permalink)
New Member/Lurker
Region: Midwest
so i wont be able to swap to 2g pistons and b ok running it as a daily driver until i can afford a logger and fuel control. i sold the afc a few months ago and im saving for a dsmlink as im now running stock boost levels and stock injectors. i have a front mount and i THOUGHT i could just run a colder plug and retard timing a slight amount? will that not work?
Offline
Old 01-04-2008, 12:14 PM   #6 (permalink)
Proven Member
I dont know for sure. I had my eye on link at that time as it was, so I convinced my self to get it asap.
What your suggesting could cut it. Its going to come down to your boost level goals.
Offline
Old 01-05-2008, 03:10 PM   #7 (permalink)
New Member/Lurker
Region: Midwest
well head came off today and timing jumped took out 1 and 4 pistons and of course probably did a number on the head, but becasue of the wet test im guessing it needed rings anyway. i thought about the 2g pistons but i figured it wasnt worth the try if it could mean detonation, I located 4 1g pistons with rods and a 1g and 2g head if i can find a machine shop to drill the 2g head bolt holes to 12mm.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Reccomended pistons rings / rebuild kit mhuffman Newbie Forum 3 10-15-2007 05:47 PM
new piston and rings, head rebuild, ran fine for a bit no compression now... IA97GST Newbie Forum 13 02-25-2007 02:59 AM
New rebuild. Which rings do you reccomend? eric91gst Newbie Forum 7 10-19-2006 12:37 PM
2g pistons in 6-bolt, which rings? 95blackGsTurbo Cylinder Head & Short Block 7 10-31-2005 08:33 AM
piston rings? engine rebuild? TalonTSIYHL Problem Diagnosis 4 08-29-2005 10:17 PM
Page generated in 0.14887810 seconds (77.41% PHP - 22.59% MySQL) with 10 queries
