KRRZ350
- 32
- Dec 9, 2007
Middleboro,
Massachusetts
YES I searched & spent some time on here first! But my technical expertise is a little above the power increase faq's, and some of these questions are a bit more technical AND weren't easy to find in any of the tuning sections. Plus, I wanted to introduce myself
(Yes, I know there's a thread for that)
Hey my name is Kevin Goodwin and I run a small auto repair business in Middleboro, Ma
The majority of my work is on Nissan Maxima's, and most of my business I got initially from Maxima.org where I have a killer rep.
One of my best customers, whicked cool guy, he's got 2 I30's & an I35 that I work on on a regular basis.......... Well he just dropped off dsm #1 for me to get started on
DSM #1 is an awd 1g 6-bolt 5-speed w/high miles. DSM #2 is a 1G 6-bolt 5-speed fwd w/cams & an upgraded exhaust turbine (something about a ### spec dsm?? ne1??) Well his best time was a 13.5, with horrid 60ft's obviously.
So he just dropped off DSM #2 for me to get started on. (Again DSM#1 = 1g 5mt 6bolt fwd, DSM#2= Same but AWD) ) He wants me to 'go through it'. aka fix the suspension, brakes, upgrade bushings, and anything else I can find wrong (already did, more in a second)
Than, once dsm #2 is sound chassis wise, he will drop off DSM #1 so that I can pull the built engine from to install into DSM # 2 (awd) And hopefully we can churn out something better than a 13.5
Now, the cool part, is I get to keep DSM #1, and the beat-up engine from dsm #2
But I don't have any questions regarding my soon-to-be-mine jelopy just yet, I'm sure by the time I get to play around with that (disapointed/jealousy over non awd anyways, I might as well stick with my 250fwhp infiniti, allthough I do have a thing for boost)
So ANYWAYS. DSM #2 needs some work. I haven't gotten underneath it yet (just got dropped off the other day, drove it = you'll be seeing me alot, me likey dsm's
I'm going to end up needing to rebuild SOMETHING in the drivetrain. Still yet to determine if it's front dif/transaxle or transfercase related, but I've got some wining that is definitly not good.
SO, while I'm in there.....................
Asides from welding the middle dif, what are some other power limitations of the awd drivetrain that I may be able to beef-up if I end up doing a trans or transfer rebuild etc?
Also, man I HATE to be the guy to ask this............ But.......... How much boost can I run and what kind of power can I make? Haha, yes, I'm THAT guy. But basically, without internals, on a 1G 6-bolt 5mt AWD, what are my limiting factors regarding different power & boost levels? For example am I going to max out xxxcc stock injectors at xxx hp, or am I going to hit the limits of maf at xxx hp first? Or once I get past the limit of X (injectotrs etc) Am I going to shatter xx at xxx hp levels?
Once dsm#1 recieves the ??'built'?? engine from DSM#2 I was thinking an HX35 would probably go on as well................
Thanks a bunch guys! Expect to see me on here alot......... Eventually owning joo
(Yes, I know there's a thread for that)Hey my name is Kevin Goodwin and I run a small auto repair business in Middleboro, Ma
But I don't have any questions regarding my soon-to-be-mine jelopy just yet, I'm sure by the time I get to play around with that (disapointed/jealousy over non awd anyways, I might as well stick with my 250fwhp infiniti, allthough I do have a thing for boost)So ANYWAYS. DSM #2 needs some work. I haven't gotten underneath it yet (just got dropped off the other day, drove it = you'll be seeing me alot, me likey dsm's
)I'm going to end up needing to rebuild SOMETHING in the drivetrain. Still yet to determine if it's front dif/transaxle or transfercase related, but I've got some wining that is definitly not good.
, I've seen trannies fail 50k later from that stuff plugging up oil passages). The whining sounds like the backlash is horribly off, it's a whirring grinding sound just off coast/vy light throttle (I'm sure you're familiar with what a blown dif sounds like
