psychbiker1966
- 96
- 1
- Aug 14, 2007
Houston,
Texas
I had my cracked valve cover replaced with a nice powder coated one less than 2 months ago. Now I noticed it is leaking worse than before it was fixed. I supplied the shop with everything including all the gaskets for the cover and around the new plugs and wires That I had them put in as well.Oil is just drenching my plugs and it is leaking out ot he valve cover as well. I too it back to them thinking that they must have screwed up the 1st time and they said ..Ya This happens sometimes with these cars!!
IS THIS A LOAD OF DUNG OR WHAT??!! This was obviously their fault and should be warranted right???
The car has only 46,000 miles !!
(98 GST)
(98 GST)
... snug the bolts down by hand and check tehm at least every other week.. I know mine are loose about once a month, i jsut take a 1/4 inch ratchet and go around and "snug" them all down working from teh center out in a criss srossing pattern and it holds fine.. like mentioned above, DON"t over tighten them.. you'll end up cracking this one as well or warping it and never solving the leak
