DARKTSI
- 51
- Oct 15, 2007
ELSINORE,
California
ok i have a 95 talon tsi awd and i think it spun a bearing and now has rod knock it makes this loud knocking noise and i cant rev above 3000 rpm it gets worse as rpm increases.....i searched and it said to drain the oil to look 4 metal shavings or sumthing but my oil came out ok a lil dirty but nothing more ...........what can i do what would cost less money just buy new rods or a new block.....also what block should i get i herd sumthing about a 6bolt being good or a non turbo 2g eclipse block also or should i just find another 2g block......what about the rods 1g turbo rods or buy new oem......how hard is it to remove the block without removing the tranny doesnt seem that complicated i gots tools just to check and see if the rods and bearings are bad
