Fuel Pump...
91TurboTalonFWD
258
Jun 2, 2007
Fort wayne, Indiana
My fuel pump might be bad.
Should i just replace with a stock one or get an aftermarket type?
For right now im doing a stock setup later on hopefully a 16G
Im on a budget so bare with me
There's a test wire on your firewall near the battery. Look at a manual to see exactly where it is. There's a protective cap over the end of it and it is usually tucked against the wiring loom with electrical tape from the factory. I believe you connect a jumper from the + side of your battery to this to test your fuel pump. You should hear the pump if it is working. Sorry, I'm at work, don't have a manual w/ me to confirm this, so somebody correct me if I'm wrong here.
I agree, you should get a Walbro 190. Cheap ($100), no FPR needed, better fuel delivery. Oh, replace your fuel filter if you haven't done that in a long time.
Shit i think the fuel filter is the same one as it is from 1991 i dont think anything on this car has been changed in the engine bay
