TurboTJ
- 161
- 2
- Apr 2, 2006
Fort Collins,
Colorado
I am having uncontrolled boost issues. With boost connected straight to the wastegate, I hit 9psi. when I use a boost controller, I hit 20 before I let off. I was checking for leaks in the vacuum lines and realized that I can blow air through the line going to the wastegate and hear it come out. Should this be happening? I thought that the wastegate would be sealed. The line is fine. This is on a 1 month old evo 3 16G with an internal wastegate. Both boost controllers tested where set to 0 PSI or there minimum settings.
thanks for the help
thanks for the help
