New Head
D3monX
263
Jul 3, 2007
Fredericksburg, Virginia
what head can i switch out that would be better for my 99 eclipse GS.. maybe one that would give me a little better advantage on other gs's
+1 Jay.
The 420a head is extremely well designed. A pair of Crower 2 turbo cams, and knife-edging the intake manifold injector humps is beneficial.
how about what blocks will fit into it with a 420a head on it...with no or litle fabircation
The Dodge/Plymouth Neon block, (which is the same block you already have) and 2.4l block from the cloud car's will fit under our head, with a little re-wiring and fabrication.
edit: Also the blocks from the 4cyl Avenger and Sebring are the same.
would the 2.4l block be a good swap or will it just not compare to the 420a block
