Foreverfalcon40
- 236
- Jul 19, 2006
North Babylon,
New York
Kinda aggrevated but ahhh whatever here it goes. Bought a 6 bolt motor off a running 91 Eagke Talon with 16G, FMIC, exhaust, injectotors and SAFC. I saw this engine run and went in a test drive with the car. I was told this is a 6 bolt the 4g63 version. But here it is now after figuring out why somethings just don't bolt up like my EVO 3 Mani, timing cover etc...without modification. I did some research that the 4g61 motor is a turbo motor coming from turboed colts and mirages. It already has the BS removed.
My question is...how much HP can be thrown at this thing before it blows. For example a stock 4g63 reaches its limits at 400hp. What about this engine?
My current mods that will be going on the car are....
XS Power Big FMIC with short route 2.5in piping
Full 3in exhaust with no cat
770 Injectors with SAFC Tune
Plugs and Wires
EBay hardened intake
Turbo RFL BOV (i know now MAFT)
02 housing with dump tube
B16G turbo with evo 3 manifold
Fidanza Flywheel
Custom Clutch
Poly Filled mounts
once everything is rolling giood for a few miles I will throw on a boost controller, cams, manifold, headstuds, and a cometic headgasket.
According to the 4g63 6 bolt specs the TB AND the Intake MANI are better then the 2g. Does this still stand correct b/c its a 4g61?3
I have all the parts required to do the 6 bolt swap such as CAS with Plug and Play harness, 1g coil pack.
Should I still be following the 1g into 2g swap? Any swap advice? I have everything bolted up to the engine with a few modifications such as triming the manifold to fit over the bracket and timing cover.
My biggest fear is blowing this thing up...I spent a decent amount of money don;t want to be stuck again...
THANKS for your continuation of help!
Jason
Plugs and Wires
Fidanza Flywheel
Custom Clutch
Poly Filled mounts
Jason
