nates6969
- 119
- Jul 8, 2004
London,
Hey guys when I bought my car it had an act2600 and a welded pedal assembly with entended master cylinder rod...at first I wondered why it needed this until I realized over time the clutch pedal rod was twisting. Eventually it got to the point where I ran out of the entended rod threads...I pulled the assembly and compared it to a stock, unabused pedal assembly and saw it was twisted by about 1.25" of pedal height. I then welded this other assembly and threw it in and now after pressing in the clutch I can pull the pedal up about an inch!!! I thought the welds were weak so I rewelded it very well while spraying the bushings with water to keep them safe, but the assembly still has slop! has anyone every seen their pedals just weaken so much from the reciprocating shear stress that eventually it is just warn out? I would of thought these shafts were made of a harder alloy that would resist such twisting! Is it time to just buy the new $88 dollar pedal and $55 lever?!
