RAKK187
- Aug 5, 2005
Huntingtown,
Maryland
I think my clutch is going out, but I wanted to seek an opinion from the pro's on here. When I have my clutch fully engaged I cannot shift into any gear. However if I bring the clutch off the floor about an inch or so i can then shift into gear. In the past when I've had a clutch go bad, it has typically started to slip then go out, so this problem is new to me.
In addition, when I do bring the clutch off the floor alittle then shift into gear, with the clutch still depressed and in gear I can hear a hum from the engine, I assume from the clutch.
*Edit*
I wanted to add that It was driving fine as I started my journey back home, but on the way home It was becoming difficult to shift between gears.
*Edit*
