Oil Cooler Bracket
Whiplash
1,624
4
Nov 29, 2004
Detroit, Michigan
I need to change my oil cooler because Im getting oil in my coolant. Would I be able to swap only the oil cooler or do I have to swap out the whole engine cooler and oil filter bracket?
Be sure to replace the seal and torque it down properly. Otherwise you can bend the sealing surface and it will leak. Also no need to tighten your oil filter down til it won't turn. It will tighten itself a little. I did that once and the stud came out with the filter.
