islandigital
- Mar 24, 2007
st. Croix,
New York
hey all,
I have a avc-r and i would like to connect it to the VSS in the 1g. I realaize its in the cluster but im having 2 issues...
1- the vehicle runs a stand alone engine management and is not using the factory harness (harnes has been hacked out by previous owner/idiot) so i need to know the pin where i can tap it direct from the back of the cluster
2-since the factory ecu is gone and not hooked up i dont know what type of output the vss is or its required input if nessaccary. i know its 4 "pulses" per cable revolution but is it neagative, positive and at what voltage/amparage?
I did, when i originally when to install the boost controler, found the reed switch but everything at the time that i tried did not work for the vss in on the avc-r. a little help would be appreceated. Thanks
I clearly wasn't thinking things through.
