LoW96Rs03
- 60
- Oct 28, 2003
I hear a noise that sounds exactly like a problem I used to have which was a loose bolt banging against the downpipe. I have tightened that bolt and now I can hear a similiar sound coming from somewhere in the block or the engine. I can't really locate where it is coming from but it sounds like a bolt banging around or hitting against something making a "ting" type sound. It "tings" more/less depending on the RPM. I recently got my timing belt, water pump and everything behind changed, not that that has anything to do with it but thats all Ive done recently. Any ideas what would be making this noise?
