TSi_II
- Apr 2, 2006
Stevens Point,
Wisconsin
Well first off, I can't change my vechile profile for some reason, so here it is:
95 Talon TSi AWD
Stock 7 bolt motor
14b turbo (turbo and exhaust manifold are ported)
2.5" o2 housing with external dump
3" downpipe-back (no cat, no 2nd o2 sensor, n1 style muffler)
MBC @ 15 psi
Ebay air filter and adapter
Centerforce Dual Friction clutch
Greddy FMIC and long-route piping
Greddy BOV
SBR J-pipe
NGK BPR6ES and BPR7ES plugs, it acts up with both, no noticable change
Accel 8mm wires
Now the problem:
Under boost, the car seems like its hitting fuel cut, but I backed the boost down to 11 psi and it still does it that low, so I figure that's not the problem. After the turbo starts spooling, right around the time it starts dumping, it feels like I let off the throttle and then slam it back down mixed in with a backfire. Occasionally it'll backfire during shifts in regular driving as well. When the exhaust was made and put on, the 2nd o2 sensor was left off, so that's the reason for the 2 o2 codes I'm assuming, and didn't really think it would hurt much. The vacuum lines from the TB have been eliminated as well as the canister under the battery and everything in between, so those are the emissions codes, the others are the ones I can't seem to figure out, and I'm hoping someone has run into them and possibly had the same problems I have. Thanks in advance.
The codes (exactly as printed):
-P0136
O2 Sensor
Circuit Malfunction
(Bank 1 Sensor 2)
-P0141
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 2)
-P1500
Manf Cntrl Veh.Spd.
Idle Speed Control
Auxiliary Inputs
-P1400
Manfacurer Contrl.
Auxiliary emission
Controls
-P0443
EVAP Emission
Control System
Purge Valve C Fault
-P0125 Clsd Loop Fuel Ctrl
Insufficient
Coolant Temp
95 Talon TSi AWD
Stock 7 bolt motor
MBC @ 15 psi
Greddy BOV
SBR J-pipe
Accel 8mm wires
Now the problem:
-P0136
O2 Sensor
Circuit Malfunction
(Bank 1 Sensor 2)
-P0141
O2 Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 2)
-P1500
Manf Cntrl Veh.Spd.
Idle Speed Control
Auxiliary Inputs
-P1400
Manfacurer Contrl.
Auxiliary emission
Controls
-P0443
EVAP Emission
Control System
Purge Valve C Fault
Insufficient
Coolant Temp
