evo 1-3 trans
Danks
81
Dec 23, 2003
The Beach, New Jersey
i have a 92 tsi awd this dude im gettin the trans from has a 91 jdm trans and says its off of a evo 1-3 ...... will this bolt right up and will my shift linkage and all that bolt right up??
any info at all on the evo1-3 trans would be apreciated
thanks
do a search because I really remember reading about the splines on the input shaft that goes to the transfer case has a different number of splines and I believe it will burn your rear or center diff because they run a different speeds... Its something to check on before you get it....
(not going to write "just my .02" because its really played)
they are diffrent the evo trannys are like a 2g tranny and you will have to have the evo rear end and t.c. to work. I had my extra on for sale from my 95 rhd evo III and had alot of people wanting it sence they are built from the factory but will not work in a dsm with out swap other parts also
i searched "evo trans" and only came up with 2 useless threads before i posted this.... he is including the transfer case... will that still f me up?
ask homeboy where he got his JDM tranny and Xfer case from... if he really got that stuff and its really JDM, then he should be able to tel you where to get the rear dff
no he got it from someone else so i really need to find one if anyone knows a place or person ide greatly apreciate it
thanks
