Directly wiring a MAFT to my 1st gen with no plug.
MotownTSI
32
Dec 19, 2005
motown, West Virginia
so heres what i wanted to know. to make a long story short i ended up doing a 2g mas swap on my 91 awd, but now i sold the 2g setup to a buddy and i'm getting ready for a big change in setups. i don't have the factory plug that came out of the harness from the car. i do have the wire ends left over from splicing in the 2g mas. so what i want to know is if any one knows the wire setup for directly wiring a 1g MAFT into a 1g harness.
Thanks for your time. any thing will help. MotownTSI :thumb:
Don't know if this will help you any, but here's my wiring scheme off of my maft (v2.01). The pic I made up is as if you are looking at the WIRE SIDE, as according to the link below.
The wiring scheme for the 1g harness can be found here:
http://www.vfaq.com/mods/2GMAF-1G.html
I'm assuming that if you have a maft and don't want to cut off its plug you can find a way to connect the 1g harness wires directly to the specific pin in the maft plug. Also, note the version of the maft I have, if you have a different one, the wiring colors may be different.
