tight_tsi
- 91
- Jul 21, 2006
Lincoln,
Nebraska
I recently purchased a 90 Eclipse SOHC 1.8 liter for a daily driver until my Talon project is completed. It died when driving she told me. Got it for $100. 114k miles. I found out that there was compression getting into the cooling system, so I first pulled the cylinder head, had it surfaced, replaced the head gasket, exhaust gasket, intake mani and tb gaskets. Was filling up with water and it started pouring out of the water pump. So, tore into that yesterday and also found the balance shaft belt in pieces. So replaced both timing belts and tensioners and water pump. Battery was dead so installed new battery but the car just cranks and cranks and cranks, won't start. I double and triple checked my timing and it should be ok - it freely spun over by hand before it went back together and cranks fine. The car did sit for +/- 1 year so I'm going to drain the fuel tank and put some fresh gasoline in it first and retry but if anyone has any suggestions I would appreciate it. Thanks for the space-
