HELP have fuel and spark but no start.
Posted by theo33, Jun 4, 2009
Please Support Jackson Auto Machine
  1. theo33
    theo33 Probationary Member
    6
    Joined May 21, 2009
    Portage, Indiana
    i hav a 1g awd 5spd. i was driving fine pulled up to a stop light wnt to take off and it putted like out of gas and wont start now. im getting fuel and spark but no start. ive replaced the fuel pump and fpr. also were is the cas located so i can move there nxt. also it cranks and sounds like its gna start evry other crank but then keeps cranking
    Compression Test. left to right 135-0-0-100
    Im ordering a head gasket so besides that were is the best place to start
    Log in/Register to remove ads
  2. PaRaNORML
    PaRaNORML Proven Member
    85
    Joined Apr 23, 2009
    jacksonville, Florida
    check your battery connections and altenator, the CAS is located right next to the thermostat housing,on passenger side on the head
  3. PaRaNORML
    85
    Joined Apr 23, 2009
  4. theo33
    6
    Joined May 21, 2009
    Portage, Indiana
    so i was just checking wiring and fuses and found nothing but i started cranking on it and it started really rough spiting and sputtering then died a few seconds later. have no idiea what would cause this
  5. PaRaNORML
    85
    Joined Apr 23, 2009
    now its sounding to be more like an air delivey problem check all your piping from turbo tom intake manifold, make sure everything is tight,i realy dont belive the CAS has anything to do with this, maybe your MAF but right now im guessing something not clamped or tightened enough check your vaccum lines as well, by the way what kind of mods are you running?
  6. Tim Melton
    Tim Melton Proven Member
    66
    Joined Nov 8, 2007
    Lasvegas, Nevada
    I would say that it sounds like your mass air flow sensor is bad.
  7. theo33
    6
    Joined May 21, 2009
    Portage, Indiana
    i went checked and tightend all intake pipes still nothing so i orderd a new maf. proly b here next week ill post how it goes. thanks
  8. rEclipserGST
    rEclipserGST Proven Member
    1,313
    3
    Joined Nov 17, 2007
    G-City, Ohio
    Does it start with Starting Fluid? That would help in narrowing down the problem. If it starts with that, chances are its still a fuel problem. Do a boost leak test & compression test while your at it.
    My DSM:
    1995 Eagle Talon TSi AWD
    13.583 @ 108.440 MPH
    Loading...
  9. gridbum
    gridbum Probationary Member
    4
    Joined Feb 12, 2009
    Seaside, California
    I had an almost identical problem, found that the aftermarket fuel pump switch had a bad ground.
    I would stick with the basics if I were you. You said you have fuel and spark. Have you administrated a compression test?
  10. darkiller_666
    darkiller_666 Proven Member
    430
    Joined Feb 19, 2008
    Salina, Kansas
    Maybe losing compression do to a bad head gasket? Definitely do a compression check!
    My DSM:
    Loading...
  11. gridbum
    4
    Joined Feb 12, 2009
    Seaside, California
    Good call. Any white smoke?
  12. darkiller_666
    430
    Joined Feb 19, 2008
    Salina, Kansas
    If you dont have access to a compression check you always could... ill say first this isnt the best way or most accurate but... Take the plug off the top of your coil pack, so the cylinders dont spark. Take a spark plug out, and plug the hole of the spark plug with your thumb or finger. Turn the car over, you should feel the compression. Do to all cylinders 1 at a time. If one or two seem to have less push or none at all, bad compression. Fuel+Spark+compression=combustion. If you know you have two check the third.
    My DSM:
    Loading...
  13. EagleTalon1993
    EagleTalon1993 Proven Member
    90
    Joined May 30, 2009
    Tampa, Florida
    I would also say compression test, If you dont have a tester most auto part stores will let you rent one. It sounds like valve timing from what you described as much as I hate to say it. Have you ever had the timing belt changed ?
    Loading...
  14. theo33
    6
    Joined May 21, 2009
    Portage, Indiana
    timing belt was just recently done and ran fine after. it blows black smoke most likly from a super rich A/F witch is making sence that it is an air problem. i havent got to compression test yet ### ive been working so much. im off to get one tho monday when i go back to 12s. thanks ill b posting maf progress ths week and compression numbers nxt week. thnks
    !!!will have compression numbers in bout an hour!!!
  15. theo33
    6
    Joined May 21, 2009
    Portage, Indiana
    so just did test. its bad from left to right #1 135 #2 o #3 0 #4 100.
    were would be the best place to start on this. im ordering a performance head gasket anyway so besides that.
  16. darkiller_666
    430
    Joined Feb 19, 2008
    Salina, Kansas
    Pull the head off and take a look! Ive done it on my car 4 times replacing "bad" head gaskets, that turned out to be a warped head surface. You could have bad valves, a bad head gasket, warped head, improper torquing of head studs.
    My DSM:
    Loading...
  17. theo33
    6
    Joined May 21, 2009
    Portage, Indiana
    ill b up bright and early 2maro morning ripping off the head. ill keep evry updated.
  18. brynden29
    brynden29 Proven Member
    117
    Joined May 15, 2002
    Round Rock, Texas
    Maybe you jumped timing when you started and bent a few valves? Might be worth checking your timing so you can know what happened before pulling the head off.
    Sorry for your loss man, good luck.
    My DSM:
    1991 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
