shadowdrag
- 191
- 1
- Oct 17, 2005
Beaverton,
Oregon
Engine still misfire, getting closer to a solution. When engine is running, every 2 minutes it will cut and go, engine jerks a little. I pull out the 550's and put back in the stock with the stock ECU, nothing happen. So I clean out the 550's and reinstall it with the Eprom ECU nothing happen, engine still doing the same. While engine is still running, I unplug cylinder 4 sparkplug wire engine sounds the same and moving onto cylinder 3. The minute I unplug it, engine rpm lowers down and start back firing and stumble as it was going to die. So I did the same to all and only 3 and 1 will react this way. This leads me down to just 3 and 1 being in the crap hole.
Any help will be appriciated.
