Few Screws snapped!
1992EagleTalon
Apr 29, 2006
LaCrosse, Wisconsin
Alright so i was putting some new 1g headlights from ebay in and two screw on the right headlight snapped and the remainder of the bolt in stuck inside the hole... how can i get these out or will i have to drill them out and retap them?? does anyone know an easy and simple solution to this problem? thanks
go to the hardware/parts store and by yourself a drill bit that is designed to dig into broken screws...It should bite into it and pull it out....basically its a screw that spins oppisite (left) of normal (right)and will pull it out....if not then you get to drill it out, have fun
