Mentow
- 38
- Nov 25, 2005
Florianopolis,
South America
what would made this happen? Its a fully stock 94 eclipse turbo, but higher turbo pressure (about 20psi at that time only heheheh)
it just happend 500miles after a head rebuilding, during a fuel pump test, driving it 3 times at 7500rpms. 5 minutes later i got a ticking sound that seemed like lifters (a brand new full set of johnsons). My car had not any, i mean *any* ticking sound before that test. Yes i was stuppid to drive it for more about 50miles when the noise got so high i was hoping to not lose my engine. God dam***!
in so stupid...
Bad oil? Too much turbo pressure (4g63 can handle about 450hps stock, doesnt it?)? crankshaft bearings with too much wear (out of spec)? BAD LUCK? heheh. Will i lose the crankshaft?
Regards,
Michel
in so stupid...Bad oil? Too much turbo pressure (4g63 can handle about 450hps stock, doesnt it?)? crankshaft bearings with too much wear (out of spec)? BAD LUCK? heheh. Will i lose the crankshaft?
Regards,
Michel
heheheh...it was just a matter of time.
manual, this is what i found:
