T is for TURBO
- 2,250
- 25
- Jan 15, 2005
Milwaukee,
Wisconsin
Okay, So I recently completed a six bolt swap into my 96 TSi. The car runs GREAT pulls hard at 15lbs... However, If I drive at a fairly consistant speed, I will get a Random misfire CEL. I know this is common as I'm using the green lid CAS. But my question is; The common random misfire CEL with the six bolt swap; is it really misfiring or is it just a phantom CEL?
The reason I ask this is because my car is actually misfiring. It boggs down, and I get no power. If I restart the car, its fine, or if I slow down and bring my RPMs down, it will go away. Once I park the car, I clear the CEL and it will stay off until it happends again.
I haven't had a chance check the plugs, wire, coil pack, or transistor, as I just got the car on the road yesterday... I know I have boost leaks, so Im sure this is could be contributing. If I switch to a black lid CAS will this help? or do you think its more related to the plugs, wires, coil, transistor, and boostleak issue?
Thanks!
-Shawn
Thanks!
-Shawn
