nuclearpenguin
- 164
- 2
- Jan 28, 2006
park city,
Kansas
After having all these problems and assuming my timing belt skip a tooth, I found it was really loose so I decided I'd reset my timing to spec and then try to retense the belt and track down the problem. The issue here is, I can't get the crank to rotate any further. It's come to a stopping point and refuses to turn any further CW. I'm under the assumption I'm hitting valves. How can I get around this?
Thanks
Thanks
I hope my valves are ok.
It's a poor mans leakdown tester, (~20 bucks, discount isle, ftw
),but it works for what you want to do.
), and a set of quick release fittings to put on the air tank hose. I've done this several times to check/diagnose cars in another state/away from the shop. If you're quick, you can check the whole motor on one tankfull.
