gst25401
- 80
- 1
- Oct 31, 2005
martinsburg,
West Virginia
The t-25 finally blew. Is it safe to drive until I can get a replacement?
Is it ok to drive?
Is it ok to drive?
Samzer said:Not recommended man.
.........+Defiant said:Yes, maybe. Or, not. Depending.
brute said:It depends on what part is broken.
If the flapper is broken or loose, it could come off and ruin your o2 sensor and/or cat on the way out your exhast.
If the seals are completely gone, you might be able to lose so much oil to drain your motor and cause a seize.
If the turbine housing is terribly cracked, exhaust gasses can melt some stuff in the engine bay (fan shrouds, wires, etc.).
If a fin or two break off the compressor wheel while it's spinning, they can enter the intercooler and ruin it.
Shall I continue? Just think about it. Anything that can go wrong, will. Sure they're all just possibilities and may never happen, but ask the question: "What if it does happen? Do I really want to risk it?"
can you elaborate on why, and what could go wrong by doing so
