VanIsleDSM
- 407
- 4
- Aug 23, 2006
Victoria,
I have my valve cover off, doing a bunch of crap.. so I got a new PCV valvle, the local parts place had a fram brand valve.. I took it home and blew on either side.. air goes out easily as it should, and when blowing on the other side it does block most of the flow.. but if I blow hard a lot goes through.. now I know from blowing on the nylon hose of a boost gauge that I can only boost about 4-5psi with my lungs.. that thing is gonna leak a lot of air at 14psi.. I know it'll be a little better once it's oiled, but still.. is this normal for a new valve, do they not completely seal? I know the best option is to use a nice check valve from mcmaster-carr or something but I'm not at the stage yet, what's a good brand of pcv that doesn't leak when new?
