Stangmurdera
- 149
- 1
- Sep 29, 2004
Charlotte,
North Carolina
I currently put an engine in my 90 Mitsubishi Eclipse GST and am having major problems. I started it for the first time this past weekend and I had no problems. I was getting spark and the engine sounded good except for an oil leak from the banjo bolt holding the turbo feed line. I fixed this issue and put some of the car back together and now I can't even get the car to spark. On top of no spark, the starter runs as soon as I turn the ignition on and will not stop even when I remove the key. I have to unhook the battery or it will continue to turn over. I had none of these problems when I started it this weekend. The only thing I have done since then was remove the canister and some of the vacuum lines that I don't need. I printed a diagram of the needed vacuum lines from a dsmtuners thread. Are the starter and no spark issues related? What should I check for? Please offer any advice to help me get this car running finally.
