ivj
- 55
- Sep 12, 2006
Renton,
Washington
Ok so my tranny is throwing me out of the first gear when I let go off the clutch - I have to do it SUPER smooth without reving above 1k rpm in order for it to stay put. It works just fine once the car is rolling though, so I believe it's the synchros (although I'm not sure why it works once the car is rolling) and my mechanic neighbor agrees with me. I've been starting uphills in the 2nd gear for a few weeks now
Ok so I'll be doing a rebuild, and I understand while I'm at it I should get the following:
1) Synchros - do I by them from mitsu? Or is there some better aftermarket alternative?
2) Throwout bearing - Mitsu or aftermarket?
3) Clutch slave cylinder - mitsu or aftermarket?
4) LSD kit for $200 from slowboy
5) ACT 2600 clutch
6) Slowboy's 12 lb Steel flywheel
Is that it?
Also, I want to adjust the gear ratios (my 1st gear is way too big and 2nd way too smal... when going from 6k RPM in first up to second RPMs drop to like 3 K, also first gear spins the wheels when the turbo kicks in, even on dry pavement)...
Video games make it look so easy, but I'm guessing all I gotta do is for 1st gear and 2nd gear I gotta get a total of 4 new gears (for the main and counter shafts), 2 of them synchroed, and it should be a pretty simple swap, right?
If so, where do I get those gears?
)Ok so I'll be doing a rebuild, and I understand while I'm at it I should get the following:
5) ACT 2600 clutch
Is that it?
