BISS screw location
nube90
386
Mar 16, 2006
terra alta, West Virginia
Im trying to fix my idle on my 90 TSi and I dont know where the idle screw is can anybody tell me where its located or does anybody have a picture of it I have a manual but its for a 2g. thanks.
What is wrong with your idle that you need to fix? The base idle speed set (BISS) screw is only used to center the idle speed controller within its range. Odds are if you're having an idle problem, it's something more than the screw being out of adjustment. Nevertheless, here's the vfaq page for adjusting the BISS screw. http://www.vfaq.com/mods/BISS-1G.html
The www.vfaq.com site is very helpful if you've never heard of it before. You'll find that many of your questions can be answered there without the hassle of starting a thread.
Best of luck!
Thanks guys thats where I thought was but I couldnt see the screw because the guy that owned it before me thought it was a vaccum leak and plugged the hole of the some kind of glue or putty.
