numlock666
- 277
- 3
- Sep 27, 2005
Long Beach,
California
I was driving around in fifth and came to a red, so naturally I start braking and downshifting. Problem is I couldn't get it into gear, and clutch pressure went out the window. So Im like OK, and start pumping it and pressure came back but still couln't get into any gear, not even fifth. So I pull over and at a stop, try to put it in any gear and it wont go in. Turned the car off and it goes in all gears. So I put it in 1st with the clutch al the way down, start the car and to my surprise it moved, so i figured the clutch is stuck on the flywheel and wont disengage, so on the drive home in 1st I try the clutch again and to my surprise it diengaged but not the funny thing, it wouldn't re-engage when I left off the pedal. It rengaged a little to the point of grabing just a bit to get me up to 10 mph at like 4K rpms. Seems as if the clutch is stuck. Fliud is full, dont see how air would get into it if it was never opened up to let air in. Also should the fluid fall and rise when the clutch is pressed because it isnt.
