Wells
- 97
- Jun 20, 2006
kc,
Missouri
One more question ..
Ever since I got my 6-bolt in, my car has died after coming to sudden stops. It also happens when I get on boost and then put the car in neutral. For example, I'll do a third gear pull and then put it in neutral .. The rpms will drop and then the car will die, I have learned to keep it in gear (which it doesn't die afterwards).
I'll reverse out of my driveway, and I have to keep the rpms up to keep it from dying .. then I'll drive down the street and then slow down using first gear .. and it will idle perfect.
The same will happen when I go to a light, as long as I downshift .. It's fine, but if I have to suddenly stop and don't have a chance to downshift .. then I stop with my ebrake while keeping the rpms up .. or it dies ..
I've been told that the dejon intake might be the problem .. I was considering getting getting the gm maft setup, but didn't want to cut into my uicp unless I had to (because I would set the blow through setup so I could vent my bov if I did that) I just didn't want to spend the money on the gm maf and the translator, and then have v3 of dsmlink come out and have that part of the new program ... and yes I have zip ties/wire holding most of my sensors together ..
I'm replacing my b&m fpr, with an aeromotive one as soon as I find all of the fittings, and I'm hoping that might be the cause.
