Couple questions about 4 bolt rear end and axles with pics
Deadly BlaZe
1,890
5
Oct 2, 2004
Alpharetta, Georgia
Ok, the following is a picture of 4 bolt axles. Is one shaft supposed to be bigger than the other?
And also, what is this?
steve said:
Yes, the right side rear axle For LSD equiped cars has the two sets of splines.
The second picture is the LSD differential carrier and ring gear.
Steve
Does the LSD differential carrier fit inside the differential?
steve said:
Technically the differential is inside the differential carrier but your thinking about the outer case that you see under the car that the differential carrier fits into.
Steve
Aah gotcha. Thanks for the help.
