take a 92 talon all wheel drive turbo and swaping it into a 98 eclipse n/t
Newbie ForumBeginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section.
i am trying to find out if i can take a 92 talon all wheel drive turbo and installing the engine into my 98 eclipse n/t and also can i the all wheel drive kit off and installing it on my eclipse eclipse to. if i can what do i need to do and what do i need to get for my car to do it.
the engine will fit, but you'll need to replace the ECU and most of the wiring harness among other things. the AWD system from a 1G AWD will not work, but you'll still need a new transmission.
the engine will NOT fit. a 2g n/t has a 420a engine. You would need to cut out and reweld all new engine mounts and spin everything around in the engine bay to get the engine to sit inside there. Its going to cost more to get a turbo engine to fit into the 2g and it would take more time to do then for you to get a part time/second job to help pay for a 2g turbo awd.
Exactly^^^^^^^^. The two motors are opposite of each outher, hence the engine bay and mounts are different.
Mike
The engine will NOT fit. I've just recently tried to do the same thing,(Tsi engine into an Esi) but the frame is "backwards". You can do it but it will cost you. Its cheaper and easier to buy a 2g shell that came stock with a turbo for the conversion.
Ken
98 Mitsu Eclipse Spyder
96 Eagle Talon Tsi
95 Eagle Talon Esi
