EGR BLOCK OFF-VACUUM LINE QUESTION! Need Help fast!!!!!!!!!!!
Status
Not open for further replies.
turbodohc20
39
Apr 8, 2003
Delaware, Ohio
I'm in the process of blocking off my EGR valve and eliminating all vacuum lines according to this: http://www.taboospeedshop.com/emissions.htm Problem is on my car there is a line coming from the Evap emission canister and going to my brake master cylinder. It is larger than ther other vac lines and turns into metal under the intake. http://www.taboospeedshop.com/emissions.htm does not show this line. \they show only one line coming off the canister and going to the purge control valve and T into the Evap emissions purge solenoid. WTH I'm I suppose to do with it? If I remove the canister and that line my brakes won't function properly will they? Please help I have the car torn down as you read this and its starting to rain.
Thanks :thumb:
OK, I'm retarded, the line I said goes to the brakes actually goes to the gas tank. but still that page doesn't show it, what do I do with it? just leave it dangle? plug it?
thanks
OK, well I finished everthing up exept that line. I just left it dangle. Doesn't seem to be affecting anything. If Anyone knows if that's OK or not I would appriciate a reply.
thanks
Status
