| Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this section. |
07-12-2004, 04:56 PM
#1 (permalink)
Proven Member
Region: Gulf Coast
rc 550's? without safc
i was wondering if i could throw in some rc 550's without doing n e thing else. i am getting a good deal on the injectors and need to know if i could throw them in without hurting my car.
Offline
07-12-2004, 04:58 PM
#2 (permalink)
Proven Member
Car: 06 EVO IX SE
Region: Tri State
It's probably best if you wait til the last possible moment to put them in the car....usually when you're about to put a bigger turbo in or about to tune the car. Otherwise injectors really don't add anything special like horsepower....it's best to wait til you get an SAFC before putting them in though. Buy them, but hold onto them because you're gonna need them anyway.
____________________________
|-Adam-|
2006 EVO IX SE (335whp/325tq)
Offline
07-12-2004, 05:08 PM
#3 (permalink)
Proven Member
Region: Gulf Coast
so i can put them in at the same time as the safc and get better results? after i get the safc what would be the best ratio for the fuel/air mix. maybe i should ask that question i a different forum. that why im here in the newbie section, so i learn and not break my car. thanx for the info. oh, safc II or the safc I which is better. i can get a good deal on the I.
Offline
07-12-2004, 05:16 PM
#4 (permalink)
Proven Member
Region: Rocky Mountain
You have to tune the entire fuel curve after installing these. You can make a few minor adjustments just to get it driving about right, but the performance requires patience and practice...
Offline
07-12-2004, 05:19 PM
#5 (permalink)
Proven Member
Region: Gulf Coast
where can i go to get the info on how to tune with the safc. i guess that i need a logger to, to find out what ratio is the best for my car .
Offline
07-12-2004, 05:48 PM
#6 (permalink)
Proven Member
Quote:
You got it.
Datalogger + SAFC + Injectors
All at the same time, or logger and SAFC first. If you put in the injectors without anything else, you'll run pretty rich and it'll idle/run like crap.
Offline
07-12-2004, 06:07 PM
#7 (permalink)
Proven Member
Buy them and hold on to them. Use them later on.
Listen to the others, you can not use them properly without a control of some sort. You stock setup is set for the weaker injectors and will cause you to get:
Poor Gas mileage
Rich running condition
Shitty idle/ rpm will get lumpy
~Chad
Offline
07-12-2004, 08:40 PM
#8 (permalink)
Proven Member
Region: Gulf Coast
thanx for all the info guys. i am going to go ahead and get the safc I,the injectors, and then the only thing i will need is the datalogger. which i will get with my next check(the 30th). is there n e special way that it is suppose to setup or does it come pretty well tuned for a stock car. i will also get the walbro 190, since i heard that the walbro 255 is to much for a basically stock car unless you get the afpr to go with it. i might do that too. what is your opinion on that. walbro 190 or 255
Offline
07-13-2004, 10:58 AM
#9 (permalink)
Proven Member
Region: Tri State
eh, you should be alright with a 255 low pressure pump. I have one on right now and I don't notice any difference in performance. It may be running a little on the rich side, but if you plan on going with something bigger than a 16G in the future then you may as well save yourself the money and get a 255.
Offline
07-13-2004, 02:52 PM
#10 (permalink)
Proven Member
Quote:
I am running the same type system as you and my next step after the new tranny is in is an AFPR. The thing we don't really see is the rich condition at idle and inbetween shifts. It is too much for the stock FRP. He will be fine for the time being, but it WILL overrun his FPR even at low pressure.
~Chad
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
