7-bolt Bedplate torque spec's & sequence
952g63t
401
35
Mar 19, 2012
Summit Point, West Virginia
I've searched for a while now and cannot for the life of me locate this information. Just want to make sure I have it right.
What is the toque specs and sequence for the main girdle/bedplate for a 7bolt?
Thanks a mil.
edit: found some torque specs - can someone confirm? 216in.lbs/18ft lbs. +90*/degrees
Did you ever get the torque sequence for crank girdle I couldn't find it either. Head torque sequence would be helpful also. I found link like you but no dice. Terrible manual.
Download a service manual. All this information is in there.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
