im a noob. spark?
Mrmasonn
Oct 23, 2011
los angeles, California
Any body have any tips? it runs pretty decent. any specific spark plug better then the others? Anything i should be looking out for? also the 4g63 can be swapped for my normal gs engine right?
No you can't pit the 4g63 in the rs or gs models. The motor is on the other side. For example the timing belt on your car is on the passenger side. On the 4g63 its on the driver. It can be done but there's alot of fabrication and money involved. It would be cheaper to just buy a gst/x.
urmomsaniceguy is correct. as far as the spark, stick with NGK copper. I had some none NGK platinum and let me tell you now, You can fill the differences. Make sure your correctly gap them at .30. that makes a differences to. I believe is smaller gap for bigger boost.
