4G64T
- 135
- 3
- Sep 22, 2003
Sacramento,
California
I just received a perfect condition hx50 threw my work at nellis, there is minor surface rust from being in a open engine bay but the turbo is in perfect working condition absolutely no shaft play came off a low miles vehicle. looking for $400
here are the specs
Comparable to a Modded H2E
Compressor side:
66mm inducer
99mm exducer
4" inlet
Flows around 1000cfm
Turbine Side:
86mm inducer
77mm exducer
T4i Housing
4" v-band exit
here are the specs
Compressor side:
66mm inducer
99mm exducer
4" inlet
Turbine Side:
86mm inducer
77mm exducer
T4i Housing
4" v-band exit
