Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Handling Tech
Handling Tech Suspension, steering, brakes, tires, lightweight wheels, bushings, etc.
Reply
LinkBack Thread Tools
Old 01-12-2004, 05:01 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: GS-T drop top is an unknown
Best install instructions for 2g rear sway bar...
Quick question, and it should be basic,
HOW DO YOU INSTALL THE REAR SWAY BAR (W/ BUSHINGS) ON A 2G ECLIPSE?
I HEARD IT IS EASY AS LONG AS THE AFTER MARKET EXHAUST DOESN'T GET IN THE WAY. I HAVE FULL THERMAL TECH PIPING AND WAS WONDERING IF ANYONBE KNOWS HOW TO DETERMINE WHETHER THE PIPE IS IN THE WAY, AND HOW TO GO ABOUT INSTALLING THE BAR CORRECTLY.
PLEASE HELP, DON'T HAVE THE CASH TO HAVE SOME ONE ELSE DO IT!
thanks
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 01-12-2004, 05:07 PM   #2 (permalink)
DSM Wiseman
jtmcinder's Avatar
Region: Midwest
If your muffler is tucked way back in and is within three inches of the subframe, then there might be a problem. Otherwise, the rear bar is an absolute snap. Fifteen minutes. The b*tch is the front bar.
- Jtoby
ps. SHOUTING is uncool and makes it harder to read the post
Offline
Old 01-13-2004, 12:37 AM   #3 (permalink)
Proven Member
Reputation: KNIGHTRIDER187 is an unknown
I have this problum too...my fron was not a problum at all it is the rear due to not having the bushings to mount it....this may be because i am not cool enought to have the turbo addition?...any suggestion on what i am to do?...i have an apexi N1 exhaust
Offline
Old 01-13-2004, 12:38 AM   #4 (permalink)
Proven Member
[quote]Originally posted by KNIGHTRIDER187
[b]I have this problum too...my fron was not a problum at all it is the rear due to not having the bushings to mount it....this may be because i am not cool enought to have the turbo addition?...any suggestion on what i am to do?...i have an apexi N1 exhaust will this be getting in the way
Offline
Old 01-13-2004, 01:04 AM   #5 (permalink)
Banned
Reputation: hoffman is an unknown
which rear sway bar did you get? i know RM Racing sways will clear Thermal exhausts.
easiest way to install.
1. put it on jack stands
2. remove a wheel. your preference.
3. remove the stocker. pull it toward the wheel you removed.
4. install the new on in reverse order you pulled the old one.
5. put the wheel on
6. put the car on the ground
Offline
Old 01-13-2004, 09:44 AM   #6 (permalink)
Proven Member
Region: Southwest
Classifieds Rating: (4)
Reputation: jim97gst is an unknown
Depending on how old/corroded your sway bar endlinks are, they may be a pain to get off. I ended up having to get the passenger side one cut off. New ones are cheap though at about $15 from the dealer.
I would recommend also leaving the plastic wrap on the bar while installing it, and removing it once the bar is in place to save the finish.
Offline
Old 01-13-2004, 03:43 PM   #7 (permalink)
Proven Member
Reputation: Creed32 is an unknown
im not sure biut idont think either of the spyders(gs or gs-t) came with rear stablilizer bars. i know my gs doesnt have one. Will the rm stabilizer bar still come with everything i need to install it?
Offline
Old 01-13-2004, 04:56 PM   #8 (permalink)
Proven Member
Region: Southwest
GS did not, GST did. Apparently GT also did not, whatever that is (see link below).
No. You need to buy about $150 worth of parts.
http://www.rernetworking.com/rmdsm/stabilizerbars.html
Offline
Old 01-13-2004, 05:54 PM   #9 (permalink)
Banned
it depends. some GSes DID come with rear sways. I have swapped a GSX rear bar onto one before. If not, my friend got screwed on his GST cause it came with a 420a engine
Offline
Old 01-13-2004, 11:22 PM   #10 (permalink)
Proven Member
sWAY BAR INSTALL
Quote:
i GOT THE THERMAL TECHNOLOGIES FULL EXHAUST SYSTEM.
aNYONE FROM THE BAY AREA WANT TO HELP ME PUT IT IN?
aLsO, iF i STArT THiS pROjECT, aNd GET tHE StOCK sWaY bAr Off AND rUN InTo PRObLEMs, wIlL IT StILL BE dRIVaBlE WitHoUT ANy sWaY bAR AT aLL????
pLEAse AdviSe?
Offline
Old 01-13-2004, 11:22 PM   #11 (permalink)
Proven Member
sWAY BAR INSTALL
Offline
Old 01-13-2004, 11:30 PM   #12 (permalink)
Banned
please stop the all caps and make coherent sentences. thanks
Offline
Old 01-13-2004, 11:34 PM   #13 (permalink)
Proven Member
Reputation: bigroy_80 is an unknown
just a quick question but did you capitalize certain letters just randomly or ## second to last post. kinda confuses me
Offline
Old 01-14-2004, 09:22 AM   #14 (permalink)
Proven Member
Region: Southwest
There shouldn't be any need to remove the rear sway bar to install the exhaust. The car will still be driveable without a rear sway bar. It will just understeer even more in a really hard turn.
Offline
Old 01-14-2004, 12:48 PM   #15 (permalink)
Proven Member
Sorry about that, clarity needed...
I meant:
I have the 3inch full thermal tech exhaust from front to back already installed, and I want o fit in a rear 3/4 ST sway bar with bushings.
i am wondering if i will have enough clearance to get the old out and the new bar in.
And if i do have any problems with the project i wanted to know if i could drive with out a rear bar at all until I have someone who know more put it in.
Thanks for the advice!
Offline
Old 01-14-2004, 11:45 PM   #16 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: Toshiro is an unknown
I've driven a lifted Jeep with no sway bars and a removed traction bar... so an Eclipse without a rear will get you where you need to go just fine. Just don't hot rod it.
Offline
Old 01-16-2004, 03:30 AM   #17 (permalink)
Proven Member
Classifieds Rating: (3)
Reputation: SlowSpyder is pretty helpful and trustworthy
The ST sway bar WILL NOT fit with your Thermal exhaust. Youll either need to get a different sway bar like an RM sway bar etc. or fabricate something to lower the ST sway bar so it will clear the exhaust. The ST sway bar was designed to work with exhaust that run through the stock location, not exhausts that go under the rear undercarriage like the thermal does
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.25984406 seconds (66.95% PHP - 33.05% MySQL) with 9 queries
