tylerdurden801
- 142
- Nov 2, 2003
OK, I recently picked up a 93 TSi and definitely will be doing the MBC/TBE/UICP mods, but that'll probably be it for engine work. Suspension mods are probably more urgently needed on this platform, so I've been researching my options. FYI, my last car was a modded CRX, and while it wasn't fast it handled incredibly well. That's kinda my benchmark here.
I know the 1g isn't as great a platfrom as the 2g due to the strut type front suspension, but there are many good handling cars that utilize a strut setup. I'm trying to find out why I couldn't make a 1g handle well.
I know some of the things a 1g owner fights: too little travel in front, poor spring rates, poor camber curve in front, and kinda dinky rear sway. So to counteract these shortcomings, I've planned a setup. Up front, GC coilovers (probably 350/350 or 400/350 as this is a mostly street car) paired with Yellows up front (shorter body for more travel), GC upper mounts (more travel again) and camber plates to dial in some static negative camber (a little less than 2 degrees should be a good street compromise). In back, GC's with AGX's (really couldn't stand the Yellows in back since they aren't adjustable on the car) with camber at about 1 degree negative, maybe slightly less.
I wouldn't upgrade the rear sway unless I found it necessary after I'd dialed the car in with this setup. From what I know you don't want to be picking up drive wheels in corners, and DSM's have four of them. I'm not sure if the RM sways lead to inside rear pick up or not, though. I'd like to see if I could balance the car with springrates.
Alignment is always important, and I'd really like to use at least some toe out up front to get nice turn-in (whether or not it makes the car faster, good turn in improves the handling "feel"), probably somewhere in the 1/32-1/16 range to keep tire wear ok (I ran 1/8 on my CRX and it turned in like no car I've ever driven, but I think that setting on a much heavier car like a DSM would lead to some nasty tire wear). Zero toe out back of course.
Sorry for the lengthy post, but can any of the suspension gurus tell me anything I'm missing in this setup? It looks good on paper and is $400 less than JIC's. Are there any other tricks to make a 1g handle well? I'm not too worried about the rear toe eliminator kits at this point, as there are other cars that handle very well that also have these types of systems. Thanks.
It was right before "Octocross" which takes place on a much bigger course than normal at SRP.
