NOMIEZVR4
- 359
- 21
- Nov 5, 2002
Chicago,
Illinois
I am trying to remove the inner tie rod. I have taken the bolt off of the outer tie rod and am trying to get the inner tie rod off. This is the driver side inner tie rod. I cant get it to break loose and turn. I tried using PB blaster, everytime i turn the tie rod from the rod,the rod the bearing turns. So than i went to the end of the tie rod put pliers on there and all i do is just strip it, it wont turn. am i doing something wrong? do i have to something with the washer?
You'll need a tie-rod removal tool. Go to AutoZone or Checker/Schucks/Kragen and rent one. You'll need to put down a deposit, but you'll get it back when you return the tool.
