1G Greddy Front Strut bar Help
rivet0r
490
Sep 22, 2002
I picked up a Greddy front strut bar locally yesturday, but it didn't come with any instructions.. I was wondering how I should adjust it. Should I have the strut pull inward, or push outward? And how exactly do I adjust it? Any help would be great, I know it's simple, but I want to make sure I have it right.
-rivet0r
it will only fit on one way...and that is the way it goes on. As far as the instal, everything needs to be loose. put it on so that it has a even amount of threads on eatch side where it adjust and unscrews. Once it is adjusted to the right width, you want to bolt it tight to the strut towers. After that, you will need to tighten the jam nuts on etch end. Once everything is on, it should be solid:thumb:
