NAT01
- 194
- Jun 26, 2003
I just noticed something about my car. It looks as if the rear wheels are on an angle. They seem like the bottoms are sticking out farther than the top. It also looks like the rear portion of the wheels are sticking out farther than the front. I do have coil-overs installed, could they be the problem? If they are, then i think that i'll have to put back on the stock shocks so that i don't screw up the tire tread. It did have an alignment done when the coil-overs were installed. The only coil over that i've adjusted since was the back left, because it looked as if it was lower on that side. Thanks for any suggestions
