Rallsport
- 41
- Sep 9, 2002
Well I finished the JIC installation over the weekend and along with it Energy Suspension bushings and stainless brake lines. I purchased all of it from Road Race Engineering (~$2000 for everything). I had Road Race do the initial setup with their spring rates and settings for the extra $100. Started the install on Saturday morning and had some help from my friends, all said and done it took 75 manhours to do the installation. The bushings were a bi***, you do have to burn them all out. Also, when removing the rear suspension the ABS sensors would not come out so I had to cut them and then burn those out (they will get replaced). I had Ingalls camber adjustment in the rear, they were rusted out and not worth putting back in so I went back to the stock upper A-arm mounts in the rear. I used a whole can of PB blaster (best stuff on earth) which helped a lot in removing the corroded bolts. Everything was anti-seized when putting it all back together. I had the car aligned (toe was off both front and rear) I set it to zero toe both front and rear. Camber was -2.2 degrees in the rear and -.25 degrees in the front. I still have the Ingalls camber adjustment in the front, I think it would have too much negative camber without it. Driving....holycrap...it is stiff, very stiff. I haven't pushed it too much yet but initial impressions the car seems almost neutral. Most of the bushings go into the rear and you can feel it. The car does not wander over rough surfaces, it stays planted even on ribbed dirt roads. On-ramps (clover leafs) are extremely fun now 65-70 mph on 25mph rated curves....weeeeeee!. I'm running 17" BF Goodrich tires, I think the suspension can do more than the tires now. The job was a chore but it was definitely worth it. I'll be running the car on a 1.6 mile roadcourse (http://www.beaverun.com/) over the summer I'll post an update. Anyway, if anyone has questions post em.
