Please Help...
tunerkid
524
Feb 11, 2003
ok im looking to do the whole whell tire/suspension thing. irst off - springs/struts - if i get eibach springs and then get a front struts will the rest of my stock suspension be ok? like they wont blow out or anything? and if i buy struts, i just need to get the tower bar correct? and its just for the front. also what eibach springs to get,i want a good drop but i dont want it to low, 1.5 or so is what i want. anyone have a pic of their 2gen eclipse droppd to 1.5? also, if i do drop it, will 18x7.5 or 18x8 with 235/40/18 rub? what sze tires do you use? i wil deal with camber when and if it happens.thanks!
Okay, first off, save up until you can get all 4 shocks/springs at the same time. Just getting 2 will not turn out very well. Next, Eibachs Pro-Kit will drop exactly what you want, its like 1.3". 18s will fit as long as you stick to a 225 or 235 tire. Also, go with a 7.5" wide wheel and you'll be fine.
