Potenza S-03's or Eagle F1 GS-D3 ?
Eagle 5
380
3
Jan 26, 2003
Cincinnati, Ohio
Which tires should I get? Im thinking about either getting the Bridgestone Potenza S-03 Pole Positions or the Goodyear Eagle F1 GS-D3? Which tires does everyone think i should get?
ill be getting 235/40/18 size
I dunno..... For now I'd say S-03s because they've been around longer. But the Eagles seem at least in Tire Rack surveys to have better tread life, and they cost less. Take one for the team and tell us how the Goodyears are. There are enough of us here with S-03s as it is :)
Here's a test from Tire Rack pitting the S-03 against other tires in its class.
http://www.tirerack.com/tires/tests...tenza+S-03+Pole+Position&tireMake=Bridgestone
Since the Eagles are so new, it may be a while before a comparison test is done, but I hope they (or some other party) does a head to head
Im thinking that i am goign to go with teh goodyears because they have abetter tread wear 280 instead of 220, and they are slightly cheaper. They still lok to have almost as good of traction so i guess ill find out.
in regards to yoru sig
"Evil will always triumph because good is dumb"
SPACEBALLS rules!!!
