turbo_lover
- May 5, 2002
Any 2nd gen GST owners, have you noticed that the front is higher than the rear, at least on the 95-96 models, I havent noticed this much on the 97-99. So, the Eibach Sportlines drop the car 1.6, other brands that drop within the 1.3-1.7 range all give the same ride height to all four corners, so in the end, the rear still looks lower than the front. The only springs Ive seen that fix this problem are the H&R's, no matter if you get the race or sport springs (Race Springs:2.0' front, 1.75' rear. Sport Springs:1.75' front, 1.5' rear), they are the only springs that fix this problem because logically the drop the front more the rear.
Get a ruler and meausere the front wheel gap and the rear wheel gap (this is if your car is still at its stock ride height), then meausure a 2.0 inch drop in the front and a 1.75 inch drop in the rear, youll see that now the car is even. Why doesnt Eibach and other spring manufacturers notice this??
