Meklo_4G63t
- 315
- Dec 2, 2007
North Charleston,
South Carolina
I have a 91 GST that I have had for about a couple of months. A month after I had the pressure in my brake system was going to the floor. I notice the brake fluid will go low but no signs of a leak. I replace the master cylinder and bleed the lines. If im right the ABS sits in from behind the MAF sensor. I traced my lines and I have from the the left to right. Left front has good flow and Left rear had little. and right front and side had no flow. I look at the lines coming from the abs and it had flow in one and the slightly one in the other. I need some help please
