Need Help was in an accident.
98Turbbo420A
DSMtuners N/T Wiseman
369
Dec 6, 2002
I need some help guys, I was in an accident a while back doing about 25 when I was cut off and slammed into a curb. The right front tire was moved back about .5in from the rear of the fender well. I was told that my control arms were bent. So i replaced those, but the car is still about .5in from being straight. Also the car pulls to the right if I let go of the wheel. When the car is driven, and the suspension travels it makes a loud squeeking noise. It's even worse when I stop. Any ideas as to what more I should replace or check?
Sounds like you bent the strut on that side. That is what is making the bad noise and also locates the wheel in the opening.
